not 100%...i would use the search function to find out. if you can't find it, i'm sure someone here will post the correct answer.
and welcome to the boards!
Shouldnt matter, as it's hydraulic...
You will also need the flywheel, clutch, pressure plate, manual brake reservoir? pedal box, centre console, shift lever and linkages.
John
Made the swap, everything works from the Probe. But I.m having severe electrical problems. I'm using the thread to convert the atx ecu to mtx. If it don't work I'll change the harness.
