First I have to say, I have already performed a search and found nothing similar to what is happening with my car.
Here's the deal:
When driving, the trans. works just fine until I let off the gas pedal completely, at which point the trans. kicks down a gear and the "hold" light flashes. It will remain in this "holdiing pattern" until I come to a complete stop. When I accelerate once more the hold light turns off, and the trans. shifts fine. It normally only happens while in drive. Once in a while it will happen while in second, but only sporadicaly. If I keep a slight pressure on the pedal (keeping the rpms around 1Grand) the problem is non-existent.
How do I pull codes from a 89 GT atx?
Has anyone ever had this happen? (I found a few posts where it was anything from a faulty VSS, a faulty governor, or even a dist. problem!)
Thanks, -Britt-
Here's the deal:
Thanks, -Britt-
