FYI, got this off a post from Probetalk.
http://www.cyberauto.com/FordProbe-626-MX6.txt
Ford Probe/Mazda 626 & MX-6
ACT Clutches:
Performance Pressure Plate
93-97 2.5L, MZ-015, +35%, $167.81
89-92 2.2L, MZ-017, +34%, $201.89
89-92 turbo, MZ-010, +34%, $185.29
MZ-010X, +80%, $286.67
Performance Street Disc:
89-97 non-turbo (4 & 6 cyl), MZSD056S, $108.38
89-92 turbo, MZSD069, $130.23
6-Puc Racing Disc (Very Aggressive Contact): $92.64
4-Puc Racing Disc (Brutal Contact): $75.16
Throwout Bearings:
89-93, RB091 $32.34
B&M Pro Edge Short Shifter:
93-97, 45078, $148.50
Borla Performance Exhaust System:
93-95 Probe GT, 14429, $404.99
Bosal Brospeed Exhaust:
93-95 MX6 & 626 V6, 112-201, $449.95
93-95 MX6 & 626 4Cyl, 112-202, $449.95
93-95 Probe 4cyl, 112-203, $449.95
93-95 Probe V6, 112-207, $449.95
Centerforce Clutches:
93-97 2.0L, Centerforce I, CF003900, $199.87
Dual Friction, DF900003, $310.24
93-97 2.5L V6, Dual Friction, DF543056, $287.09
CenterforceII, CFT543056, $250.75
Centerforce I, CF056543, $214.41
89-92 2.2L Turbo, Dual Friction, DF103884, $362.87
CenterforceII, CFT361844, $218.04
Centerforce I, CF361844, $176.93
89-92 2.2L, Dual Friction, DF111812, $300.69
Centerforce I, CF361812, $145.36
90-92 3.0L, Centerforce I, CF361123, $208.96
T.O. Bearing, 091, $40.45
Eibach Alignment Kits:
83-97, Front or Rear, 5.83450K, $23.81
Eibach Anti-Roll Bars:
88-92, 4cyl, 5511.320, $321.75
Eibach Pro-Kit Coil Spring Set:
93-97, 5522.140, $224.25
88-92, 4cyl, 5511.140, $224.25
Fidanza Aluminum Flywheel:
Non-Turbo, $361.00
(Verify application)
GReddy SP Exhaust System:
93-96, GT, 10145500, $585.00
Hayden Oil Cooler:
1993-89, 2.2 & 3.0, 403, $37.69
Hayden Remote Oil Filter Kits:
291, $40.74
HKS EVC:
EVC IV, 4503-RA006, $527.12
EVC EZ, 4503-RA008, $347.60
EVC Installation Kit, 4503-011US, $15.84
HKS Intercooler Pipe Kit:
88-92 Turbo, 1302-F01US, $360.80
HKS Turbo Exhaust System
88-92 Turbo, LET-Z06, $484.00
HKS Sport Exhaust:
93-95 Probe GT, LET-F02, $484.00
HKS Super Mega Flow Intake System:
93-97 GT 2.5L V6, 1504-SPFZ05, $136.40
HKS Turbo Timer IV and Harness:
4101-RA008, Standard Black Case, $96.80
Blue,Green & Red Available, $105.60
88-92, Harness, 4103-RZ001, $11
HKS Twin Power Ignition Amplifiers:
DLI, 4301-SA005, $466.40
Distributor, 4301-SA007, $369.60
HKS Fuel Pump Upgrade:
External Fuel Pump Upgrade Kit, 132psi/65gph, 1408-M01US, $523.60
In-Tank Fuel Pump, 165psi/90gph, 1407-001US, $545.60
Adjustable Fuel Pressure Regulator, 1407-RA105, $176.00
HKS Bypass and Blow-Off Valves:
Standard Bypass Valve (engines to 300hp):
Right-Handed, 17670-025100, $66.00
Left-Handed, 17670-024100, $66.00
Racing Bypass Valves:
3.5 - 9 psi (white), 17670-014100, $158.40
6 - 12 psi (yellow), 17670-013100, $158.40
7 - 14 psi (blue), 17670-004100, $158.40
12 - 18 psi (red), 17670-016100, $158.40
(Valve Springs Only: $8.80 - $13.20)
HKS Variable Boost Controller:
88-92, Turbo, 17265-110US, $105.60
inTrax Springs (-1.75")
88-92 Probe 4cyl, 30.1.008, $219.95
93+ Probe V6, 30.1.009, $224.25
93+ 626 4cyl, 45.1.009, $224.25
K&N Filtercharger Air Filter:
93-97, 33-2049, $37.14
88-92 exc 90 Probe w/o Cruise Control, 33-2026, $38.47
90 Probe w/Cruise Control, 33-2024, $37.08
K&N Filter Care Kit:
99-5050, $7.95 (Squeeze Oil)
99-5000, $9.45 (Aerosol Oil)
K&N Filtercharger Injection Performance Kit:
93-97 2.5l V6, 57-2507, $128.50
K&N Performance Gold Oil Filters:
89-96, 4cyl, HP-1006, $10.75
90-92, V6, HP-2009, $10.75
KVR Performance Carbon Fiber Semi-Metallic Brake Pads:
83-87 (all), Front, M7169, $57.10 set
86-87 (all w/Rear Discs), M7218, $57.10 set
89-92 (all), Front, M7288, $51.82 set
89-92 (w/Rear Discs), Rear, M7289, $48.31 set
93 (all), Front, M7463, $61.49 set
94-97 (all), Front, M7515, $65.88 set
93-97 (w/Rear Discs), Rear, M7464, $57.08 set
KVR Performance Cross-Drilled or Slotted Brake Rotors:
83-85 (all w/Unvented Front Discs), Front, MA-818CD, $65.55 ea
83-87 (all w/Vented Front Discs), Front, MA-823CD, $74.10 ea
86-87 (all w/rear discs), Rear, MA-825CD, $109.25 ea
88-92 (all), Front, MA-833CD, $73.15 ea
88-92 (w/Rear Discs & 2 wheel Steer), Rear, MA-835CD, $91.20 ea
88-92 (w/Rear Discs & 4 wheel Steer), Rear, MA-836CD, $119.70 ea
93-97 (all), Front, MA-850CD, $89.30 ea
93-97 (w/Rear Discs), Rear, MA-851CD, $83.60 ea
Magnecor KV85 Competition Spark Plug Wires:
93-97, 2.5L, 65129, $163.13
93-97, 2.2L, 45245, $82.40
88-92, 2.2L, Turbo, 4527, $48.92
88-92, 2.2L, N/A, 45105, $45.06
Pace Setter Monza Exhaust System:
93-95 Probe/MX6, 2.0L, 88-1404, $164.42
93-95 Probe/MX6, 2.5L, 88-1403, $164.42
90-92 Probe, 3.0L, 88-1400, $157.27
89-92 Probe/MX6, 2.2L, 88-1328, $171.57
Pace Setter Header:
93-97, 2.5L Probe/MX6 non-turbo, 70-1161, $178.72
89-92, 2.2L Probe, 70-1060, $135.82
Pace Setter Ceramic-Coated Header:
93-97, 2.5L Probe/MX6 non-turbo, 70-1161, $307.42
89-92, 2.2L Probe, 70-1060, $Call for price
Pace Setter Air F/X Intake System:
92-96, 2.2L Probe/MX6, 16-1401, $185.87
Pace Setter Quik-Shift Adjustable Throw Shifters:
93-97, 01-0622, $114.37
88-92, 01-0620, $114.37
Razo Pedals (3 piece sets for Manual Transmission):
Carbon Black
Small, RP55, $53.27 (Retail $73.99)
Large, RP54, $54.71 (Retail $75.99)
Aluminum w/Chrome Plate
RP47, $41.03 (Retail $56.99)
Magnesium Alloy
Small, RM35, $55.43 (Retail $76.99)
Large, RM34, $56.15 (Retail $77.99)
Suspension Techniques Sport Lowering Spring Set (-1.0"):
93-97, 60310, $190.37
88-92, 60305, $190.37
Techna-Fit Coated Stainless Steel Brake Lines:
93-97, FORD-1010, $103.50
88-92, FORD-1000, $103.50
Available in red, yellow, blue, and clear
Tokico Premium Performance Struts:
93-97, Front, HB3081, $98.25 ea
HB3082, $98.25 ea
Rear, HB3083, $98.25 ea (X2)
88-92, Front, HB3031, $91.23 ea*
HB3032, $91.23 ea*
Rear, HB3066, $98.25 ea*
79-82 626, Front, HZ1064, Discontinued
Rear, HE2572, $35.07 ea
Will work with elec adj susp if modules disconnected.
Email for details
Tokico Illumina Adjustable Struts:
93-97, Front, BB3081, $140.37 ea
BB3082, $140.37 ea
Rear, BB3083, $140.37 ea
Tokico Premium Springs (-1"):
93-97 Probe V6, HPS5038, $188.84
93-97 626/MX6 V6, HPS5057, $188.84
Tokico Illumina Suspension Kit (-1"):
93-97 MX-6 V6, ILK214, $635.31
93-97 626 V6, ILK226, $635.31
Unorthodox Ultra Light Weight Flywheel:
0608105000, $500.00
This is not a complete list of every item available for this car,
but rather a list of the products that CAP most commonly sells for
it. If you don't see what you are looking for here, please
email us at [email protected] and we'll try to provide whatever
information you desire.
Finally, please note that while we make every attempt to keep our
price guides correct and up to date, we cannot promise that every
price given in this list is 100% free of error. We will always try
to honor the prices here, but must insist that this is not a quote,
but rather a pricing guideline, and subject to change without notice.
ACT Clutches:
Throwout Bearings:
89-93, RB091 $32.34
Non-Turbo, $361.00
Hayden Oil Cooler:
291, $40.74
HKS EVC:
HKS Sport Exhaust:
Pace Setter Header:
Carbon Black
Magnesium Alloy
HB3082, $98.25 ea
HB3032, $91.23 ea*
Email for details
BB3082, $140.37 ea
0608105000, $500.00
