I have read that a drain of <0.05 amps is normal, to keep the ecu memory alive (so it doesn't forget codes). The ecu runs off the room fuse. I thought the radio ran off the room fuse as well, but I could be wrong.
Anyway, a drain of 0.07amps is a little bit above what it should be, but I wouldn't have thought it would cause your battery to go flat. It's still a very small drain. 0.07amps x 12 volts = 0.84 watts, which is less than a flashlight bulb.
