OK so i did some exploratory surgery, and found my PS leak, and possibly, my rattle as well.
Part 21 is a bearing, the outer seal is.. not there (when i pulled off the pulley, i reakon i found bits of it) also suspect missing is part 20.
The seal busted off im guessing from a completely warn out part 22 (oil seal) putting preassure on the bearing... only needing something to trigger blowing it off... anyway, stupid me didnt get the dimentions of the bearing when the car was in bits, so if anyone has them, thatd be much appreciated (i can nip down to a bearing supplier and get one) If anyone has the dimentions of the oil seal as well thatd be sweet too.
Just a suggestion that may be easier for you to fix. Go to a salvage yard and pick up another power steering assembly for like $20 or so.
goddamn wish i saw that before i forked out $100 for a pump from the wreckers :(:(
