· Registered
I want to know what this sound can Be ...
I justed rebuild All the Motor. Piston Ring, New Crank, New connecting Rod Bearing and Crank Bearing... New Turbo...
But i still d'ont know how to remove that stupid cut off.....:(
· Registered
Need more info! Did you turn up the boost? Did you replace or check the throttle body boot?
· Registered
My Boost is at aprox 12 PSI.. But i change my exaush system without replacing my catalysis..... (A straight tube now)
All my exaush system is now in 2 1/2 inch with a freeflow muffler..
My Turbo is rebuild ansd is like a new but with stock impeller...
One of the reply before sais to add a chip a mod a chip what is this chip exactly and where can i buy one ?? (an internet website like will be appreciated)
Thx for answering my question .... :p
· Registered
You're hitting the boost cut @ 12psi. You'll need a chip or the VAF mod to eliminate that. Also you should probably have a boost guage so you can know what you're boosting at.
Here's Zombies site, he sells chips.
http://www.injecttech.com/
