Is there a water pump out there better than the OEM? I need to buy one as part of my engine installation.
nothing made specifically for our cars.
not sure what you'd want more out of your water pump.... as long as it lasts you're golden...if you want more cooling capacity check out the bulkbuy on probetalk for a larger rad from Howe racing
on the topic of water pumps...make sure you but the one with the correct size pilot hole in the pulley its either 16 or 32mm depending on the year of your car iirc
I was just wondering if there is one that is more dependable. I had one go out on me at around 120,000 miles, I thnk it was, causing the engine to overheat.
yes like that yo
