I am just finally finishing up on the project. It's been a long time now since I actually ran the 6 longer than around the block. I discovered today that the high performance boost controller I purchased has the fine adjustment srew stripped and stuck. i.e. Noooo movement, and consequently no adjustment. Although the coarse adjust still works. Oh well. The T-28 oil line is proving to be quite the task to get to seal. leaks constantly... Any sugestions? I went to NAPA and they double flared it for me. I tried high temp sealant. Is there a different fitting that was stock on these? Other than that the boost is quite nice at about 14 psi. Although I am running a little bit lean according to the plugs. Not bad, but we'll see. I need to take it to the dyno, but will also need dosh for that. The phantom grip works ok so far. All 10 miles of my experience with it. hehe. I wish I could report on the cam, but I did both it and the turbo at the same time, so cannot tell if is performance gain from the cam or from the turbo that I am getting, or just a combination of the two. MANNNN I can't tell you how much more enjoyable the drive is with a good stereo. I missed it. Sorry bout the long post, just really missed the ride.
