Well, I found this but it seems like a corny ass way to set boost level.
It appears that it adds the duty cycle on top of the wastegate spring pressure, which IMO is rediculous. I should just be able to set the pressure I would like the valve to open at and have it do the calculations for me :shrug:
Oh well. I guess I cant set my boost controller until the motor is broken in since Im not willing to do full throttle pulls to over 10 PSI when I only got 30 miles on the motor. :sigh:
So if my calculations are correct at 90% duty cycle on a 7psi spring i would only be able to boost just under 14 psi? Seems kind of silly. That means I would have to set a WG spring at 10 PSI just to get 17 lbs of boost (desired to make my dyno run at)
Someone tell me I am wrong please.
