Well I seem to have found out its not the brake master cylinder, it looks fine, couldnt see any leaks, however had a look around the rear of the car this morning, and there was actually a puddle of brake fluid there. Basically from the wheel back theres a spattering of brake fluid, even on the tyre itself. The caliper itself was only oily around where the springs or cable( whatever you call it is) the brake lines themselves looked dry from what I could see.. It seems to have only gotten this bad since yesterday.
Had a talk to a brake specialist , theyre going to have a look at it. However they said they would want to recondition both, since they said if they only did one, it would upset the brake bias, because the seals etc would be in a better condition than the other side( even though it was recoed 18 months ago) Are they talking crap or is that reasonable to assume?
I dont really have the time to fix it myself or try at the moment, bit too busy with work and study. Plus it looks like the right side is totally stuffed. Alternatively ill look into the ge2 calipers again
I think I better not drive the car much till this is fixed, too dangerous...
