I bought some really good pads and they work well but leave dust all over my wheels.
Should I get slotted or drilled rotors and what has anyone found thats compatible? They do work very well but as more powers being added to the car I want more brakes ( fast but safe)
ive got EBA slotted and blind drilled rotors, had them 2 years, no complaints from me.
steer away from drilled, as these crack, and a few people have complained that the DBA rotors tend to warp, though the ones on my mums 626 have been there for a year a bit now with no issues
Slotted is ok, but still rather wank factor I would say. Ive seen cars that get pretty serious track work, and they just have massive standard (blank) rotors.
Im quite happy with my DBA slotted disks.
in terms of brakes slotted is all you wil lever really need.
Go look at top rally cars - weekend circuit etc 80% all use just large slotted rotors.
the slots are the only things that help. What is deos is remove gas build up. in fact I remember reading one engineering paper - that claimed for short type large quick heat shots. Like consistant cornering short not too deep multiple cuts are most effective.
On more longer consistant temps - EG where you have long straight etc. Or sections where your braking effort is over a longer period. EG end of Bathurst- conrod straight into the chase. Your better off with fewer slightly deep longer cuts.
But I can - regardless if your dealign with stock 260mm brakes EG 1st gen or 2nd gens 258mm - Minimal leverage and well - Even stock Mazda sp23 brakes are bigger.
but good pad selections and a slootted rotor wil lbring out the best in them, as long as everything else is in same top condition.
they did seem to be brilliant but launceston has steep hills and some unreal corners, there are some fantastic roads here so they can feel worn after decent driving..
on a different note been reading insppection manual for when i do re-register, its very in depth.
good news though so long as the car doesn't emit more than 90 db from half a meter i will be okay with that ( only have 3" pipe , flex joint and cannon. but at idle once warm its not too bad... thinking bout turfing the cannon for something more street, maybe just a 3" tip
For a while I was always heating up my brakes through a decent run (when I wasnt a pussy like now) and it wasnt until I got some decent (ie expensive) brake fluid in there the the I could maintain pedal pressure from start to finish.
slotted rotors + Lucas TRW pads + a decent fluid but by no means a racing fluid.
Took that combo out to wakefield and was braking pretty late into the corners. I lost FULL pedal pressure pretty quick but braking performance never went down. Just meant I had to push harder on the pedal.
So just warm brakes but no brake fade.
