I currently have a code 3 for the "Camshaft Position Sensor" (on a 1993 LS) and was wondering if I need to replace the entire distributor or if it's just something that needs to be adjusted or replaced inside the distributor housing. Also, would rotating the distributor affect the sensor at all?
Thanks in advance for any input!
i got that code recently and i had to replace the entire distributor. The sencor is within the distributor. and you cant buy and replace just the sensor. Thanks for the karma
Reactions: Boadicea
Thanks for that! What symptoms were you experiencing? I'm guessing rough running? Karma issued! ;)
a little rough running, but when i go to start my car it would Crank for 7 seconds before starting. Thats way too long to start the car. now its an instant start. Also the check engine light was on!
