I need to replace the cap and rotor on my car and was wondering what else I should replace at the same time. I read somewhere on here that MX-6s like NGK plugs, but what wires should I get and from where? And how much?
Also, I have a good amount of oil in the front drivers side spark plug hole. What gasket needs to be replaced to fix this and what are all the parts I need? I mean, should I replace more while i'm gonna have the cover off anyway? If there are any other things I should know, please post because the car is my daily ride so it can't be down for more than a day or two.
The gasket for the cam cover. However if ur replacing this you might as well replace as many gaskets as you will come ion contact with. A manual (Chilton's | Hayes) will tell you all the gaskets and other types of seals that you will need to replace upon contact. A full gasket set can be up to $300. The labor is not easy and can run high depending on how deep in the engine you want to go.
