Hi Pushingit, You have no deatils of your car in your profile and do not specify the details in the question, so if you could update that, its going to help people help you.
I will ask this these Q's though, does it do it when you are sat stationary ? and what is your normal idle RPM's ? Does it only do it on full lock, or any amount of turn ?
For now you could check your power steering fluid, for level and quality. When on full lock the power steering pump will demand quite a bit on the engine, if your idle revs are low, it will cause it to stall.
Oddy.
