Ok, i just replaced my arm tensioner, tensioner, and timing belt, well while working on it i also moved the distributor cuz it wouldn't start but then i realize that the timing was not right, fixed that. Well once it started , i couldn't run it over 3800 rpm. What do you guys think the problem is?? Help ASAP
sounds like you need to pull the timing belt back off and set everything to dead center. I did the same thing and my cam gears were one notch off. If that doesnt work check your coil pack
i'll go ahead do that check my timing again and hopefully thats all cuz i have been checking into a disty and am trying to stay away from that. well if you have any suggestions let me know. I don't know if i said this but when cold there is not problem with the rpms at all, well thanks a lot and its another thing to look at.
