Do a compression check, since your getting spark and fuel. Dont u have to put someting else besides the copper head gasket? I have heard that u have to put some sort of seals or somethings?
Yeah, even without the IAT your car will still run.Correct me if I'm wrong, but I'm pretty sure that it is not the IAC causing my car not to start.
Correct.Though you may not want to hear it, most people that have copper headgaskets (at least f2t-wise) have always had sealing problems.
Im not sure on the cold start. Ill go research that... I know some guys who have just deleted the whole thing and had no problems other than the CEL...im not 100% on the stock ecu. it will run with no iat, and throw a cel. but probably wont cold start without it. needs to have that signal feedback to run open loop
Cmon now, you know whyedit: and why didnt you go with a MLS gasket?
Yes, you have to use crush rings or O rings to make a copper head gasket seal, I know because I did'nt have them used on my engine rebuild and my copper gasket leaked from the begining.Do a compression check, since your getting spark and fuel. Dont u have to put someting else besides the copper head gasket? I have heard that u have to put some sort of seals or somethings?
I've never heard of these. Got any links to them?Yes, you have to use crush rings or O rings to make a copper head gasket seal, I know because I did'nt have them used on my engine rebuild and my copper gasket leaked from the begining.
Oil floats on the coolant. (Oil SG=0.8, Water/coolant SG=1.0)Correct.
In fact, after letting the car sit overnight, try changing your oil and see if coolant comes out (at the end since it floats on oil).
Maybe I have it backwards. But no big deal, hope someone wouldn't drain a quart to say "oh, no coolant" and put the plug back in.Oil floats on the coolant. (Oil SG=0.8, Water/coolant SG=1.0)
