1 - 8 of 8 Posts
Ok guys I have a 93 LS and I went to start my car this morning and no go. I tried till the battery died, then proceeded to have my dad push me around the block with his beemer. It eventually kinda started but it was bucking horribly then when I got back to the house it was idling fine till I tried to let off the clutch and drive. It died immediately. Ive tried to start it but it just turns over. I ran the codes and got 02, 03, and 16. The disty is brand new so i didn't think it would be that, and if it was the crank sensor the engine should still run w/o the crank sensor because it has the backup one in the disty right? Anyone have any ideas to what it might be Im lost.
Take a look to see if you have fuel issues, as a clogged fuel line, or bad pump.... perhaps
It's not getting any spark. Haven't checked the fuel yet, just figured it couldn't be both at the same time or at least hoped it wouldn't.
I just posted an issue kinda like yours with a solution its in this forum called "good fuel and spark no run check here" might help you
Even a brand new disty could be bad. A bad crank sensor will keep the car from running and starting.
my car stalls every 1-20mins and can only be restarted after a couple hours) jerks in low gear too.... and the crank sensor was covered in engine oil and dirt untill I cleaned it... only code 69.
any ideas?
any ideas?
1 - 8 of 8 Posts
