carbon fiber hood mod! cheap and fun
5314 Views 27 Replies 18 Participants Last post by  josey_gt
12
Ok i got bored and sinch im a cheap hacker and proud to be one i figured i give a try at paint a hood to look like carbon fiber, ive tryed this in the past on test pieces with spray paint and even if you dont have a spray gun handy spray paint would even do the job on this one, i suggest buying a 2nd hood from the junk yard for 20 bucks before tearing urs apart though
for this project you need is some news paper, masking tape, 2 colors of paint black and silver work best and some tools along with some of the lining for tool boxes that you can get at any autoparts store, make sure you have sand paper 180- 320
you have to remove your hood and then start sanding your hood like you would to repaint it, but i wont walk everyone through prepping and painting i filled my mazda logo to flush it heres the pics
once you have your hood prepped for paint after you lay your base coat in my case black, you will probably need someone else complaint enough to help you not your mom or your 5 year old brother, anyways you need to take the roll of box matting and tape newspaper along the edges like so
keep wrinkles out of the matting when paint or you will get alot of overspray i used a yardstick to push down on the edges.
this is the pattern you should come out with
i would recommend you start painting from the front and go back if your like me you will end up with a tiny bite left to paint when the end of the hood flairs, to accomplish this i used a small cut off piece and lot s of tape to prevent overspray, also i suggest not doing the layers up the hood, side to side works the best to give it a inconstant look
now the hard parts done lay down whatever kind of clear coat you prefer and wait for it to dry, i hope i helped someone with this write up and please let me know if you need any help, email is the easiest @ [email protected]
Ask me any questions, i know i wasn't detailed on painting i did wet sand the primer just to help hide any imperfections when i layed the black base down, anyways thanks fellow mx6ers! hope you enjoy this as much as i do
1 - 20 of 28 Posts
Wow! I'm very impressed at how it came out, now i wanna do it!...if you want to post pics, go to ImageShack® - Image Hosting and click "Upload Image" then follow the easy instructions, copy and paste the code and voila!
Wow looks great, reminds me of a technique painters use to make wood grain they use cheese cloth
Wow! i was all ready for a snarky remark about faking it :p but i'm pretty impressed by how well it came out so i have to eat my words lol. how much time and money did it take though? do you think it was worth it cause CF hoods are getting pretty cheap and then you get the weight reduction
Wow! i was all ready for a snarky remark about faking it :p but i'm pretty impressed by how well it came out so i have to eat my words lol. how much time and money did it take though? do you think it was worth it cause CF hoods are getting pretty cheap and then you get the weight reduction[/QUOT
for me it was under 20 bucks all i had to buy was primer and that matting everything else i had sitting around i used baseline paints because i didn't want much of a gloss. if you had to buy all the suplies asumming you had the paint gun and tools id say pricing around 50 bucks to the most expensive stuff costing a few hundred but that kills the puropse of this being a cheap and effective mod
Yeah looks like carbon fiber. Personally I can't stand the look of CF and if I were to ever use it it would be to save weight and I'd just paint it to match the rest of the car, but that's me :)
looks good, better than i thought it would, and i hate to be a buzz kill but with a concentration on look more than function, this might fall under the category of rice
If i had a REAL carbon fibre bonnet i would paint it the same colour as my car (unless i had a black car), however, that did turn out pretty neat, although i think anyone would be able to tell the difference between real cf and paint, a lot of RC heli parts i have lying around here are just plastic with a photo of cf printed on them..
How did you get it so glossy. That last picture of the hood gives a great reflection of the light.
i actually used a jammin' clear which holds gloss good but still gives the hood a textured look, i didn't expect it to come out like that i just got lucky that that is the only clean i had sitting around
So no wet sanding then?
Did turn out amazing for a painted CF
To put the links directly to the forum you need to do the following without the periods.
looks good now get a shot next to a real carbon fiber hood so we can see the differance :)
verry cool.. gota say i wouldnt mind doing an entire car with that... might be cool :D
10
.i.
ok heres a few pics of it done just got it on the car, no day shots yet ill try for tommrow
ill have the new ones up soon hopefully please pm me any questions this is my first big write up and i know i wasn't in depth on everything ..
Dev MX6er 4 Life
Is it the paint sprayed uneven or is that just the lighting making those streaks?
That looks surprisingly well. You should do that to your entire car and see what it looks like.
it looks like the black base was sprayed uneven...
Someone has seen Monster Garage with the F-150 Nut-Shaker. Wood grain Flames on a blue pick up.
1 - 20 of 28 Posts
