i have a klze and im sick of the check engine light and the million sensors egr etc... is it possible to swap over to carbs? if so where do i find an intake manifold, carbs and what CFM rating should the carbs be?"
Im not sure that is possible? Anyone? You would have to custom make EVERYTHING.
And I might say you would need megasquirt a custom made one.
the custom fabricating is no problem, but I want to eliminate the EFI megasquirt or not, and run 1 or 2 carbs. I just really need to know if anyone knows the CFM numbers that this KLZE should be at as starting point, and figure it out from there. Thanks for the input
I suppose you might need a custom ignition curve to handle the poor fuel delivery of carburetors throughout the rpm band.
Yes, anything is *possible*. People have put ITB setups on the KL so there's no reason you couldn't stick a 6 pack carb on there too with a custom IM.
I'm just not going to search in order to contribute to someone who obviously doesn't understand that EFI is superior to carburetors in about every way imaginable.
incredibly helpful, thanks, I sure will be back on this site for help, Love that community feel.
Glad to help. :tup:
We look forward to pictures of your project progress. An aftermarket EMS would help with the modified ignition curve.
Ohhhh fastest up to his same old self ;).
Ohhhh Dave,... what's up? :)
