Nice work there!
How the heck did you manage that? Did you buzz the engine?
IIRC its because of the position of the stock fpr, which is right next to cylinder #1. I'll double check.Jesus! Seems everyone that blows up a motor on these cars always blows the #1.
Now that makes sense! I've also read about the fuel thing. But, is there any way to prevent this kind of failure? Or at least further prevent it from happening, by getting the oiling even?Bearing failure might not have anything to do with where the FPR is located.
However I have pulled apart a SOHC FE that oil starved and seized...and guess what...the big end bearing on number 1 was the most [fizzle]ed...you could have almost started the engine if it wasn't for the fact that bearing no.1 had welded itself to the crank.
I would say that the oiling is probably a little uneven, it could just be that when the engine oil starves than #1 is the closest to the oil pump and receives air instead of oil first, before the other cyls.
