I have had the system working before winter. You unlock one door it unlocks the other one too. Had lock freeze once and for the whole winter central lock was not working. After the car thawed completely it worked again. Same problem happened this year too but Central still don't work. Any of u have any thoughts to fixing this, I know it aint nothing big, but I would still like to fix it!
I have the same problem
because of this my alarm doesnt work and my i have to open the passenger door manually its pissin me off but i can't find whats wrong! if u hear anything let me know! Thanks
I believe that there is a motor in the pass door that actuates the lock. Check the motor to see if it works. Check for power and ground while unlocking the drivers side door. Try tapping the motor. Good luck.
