The amber bulb in my left turn signal went out, and it looks like I have to remove the headlight to get to the point where I can put a new turn signal bulb in! The top screw on the turn signal lens is one of three screws holding it in, and the other two are on the back or somewhere that I can't get to. Why in the heck can't you get to this bulb as easily as you can the headlight bulb?
Don't get me started on the bulbs in the dashboard, I can't believe I have to take the dash out to change a freaking light bulb? Wouldnt it be cool if they used fiber-optic strands from a central light bulb which was easy to change?
Anyway, if someone knows the easy way to do these things please let me know.
Thanks in advance!
Discussion Starter · #2 ·
My Haynes book was wrong, there was only a single screw on top locking it in place, it popped out and back in on some guides. Problem solved! I knew it had to be easier than the book showed it to be.
Now if there were only an easy way to change the two burnt out bulbs in the dash?
