Yep. Make sure the car is very well supported and the opposite wheel is chocked to keep the car from rolling.
Now, stand and face the wheel in question. Turn 180-degrees so you're facing away from it, then bring your leg up and literally kick at the wheel near its edge. Try fairly gently at first to see if it will come loose, increasing the force to the point the wheel pops off.
The wheel has actually corroded itself to the hub and kicking it will break the corrosion and free the wheel. It will be worse depending on how long it's been since the wheel was last off. Again, make sure the car is stable and well supported before doing this; you don't want to jar the car so much it falls off the jack
When you put the new one on, smear some anti-seize compound on the hub and on the lug nuts to keep them from corroding again. Re-check the lug torque after a hundred miles or so...
