Im new to the forum and I was searching for a cure to a problem that arises with the check engine light, but i didnt find one. Maybe someone can help. When I'm traveling at highway speeds 70-75 and I accelerate to pass, I reach above 80 mph and then slow back down to speed my check engine light will come on for about 10-20 seconds and then go off. Does anyone have a suggestions on what might be wrong. Lack of air, to much fuel, bad o2 sensor?
Very annoying problem!!
Try going to the 'Frequently Asked Question, 2 G' section. Pan down until you find how to run the codes. I just looked at it so its still there. It has a list of each code number and what each means.
Jim D
I think he needs more then this, i mean, you cant even pull the code out of the car to check it since it turns on and off when driving *bummer*. Though i dont know what to tell you, you might (untill some one who knows what their posting speaks up) call Mazda to talk to a service adviser. Note: Dont let him talk you in to bringing the car to them, just see if he has any tips to look in to.
Thanks for the help guys. Here is what I pulled from the codes. The first one was a 24, Right O2 sensor. I figure I should replace both while im at it. The next code was a 41 which corresopnds to the VIRS #1 solenoid. I found a post where they recommended replacing the solenoid with the FPRC solenoid. In the process I broke every connection for the vaccuum lines. oops! So now i have the FPR not connected at all. Is that bad? But the VIRS seems to work now! Thank goodness I didnt break the good one.
Does anyone have a clue on how much these solenoids cost?
