Is there any way to test spark plug wires with a volumeter. I have herd that there is a certain resistance they sould have in ohms. Thanks for all the help.
The reading should not exceed 16kohms per 3.28ft(1meter):muhaha:steelersfan said:what kind of reading would i expect out of 7mm ngks
4000k ohms per foot of wire.steelersfan said:what kind of reading would i expect out of 7mm ngks
it came to my mind that i had the manual somewhere so i scanned it cause i see people are saying many different stuff and the guy is getting all confused...glad to helpStealth said:good find toxic
Uhmmm No! That would be 4kohms per foot.:ewink:kc 93'ls said:Im reading 4oook per foot right out of the FOS electrical text book.
Teh- hee94MX6pilot audio master said:Uhmmm No! That would be 4kohms per foot.:ewink:
no problem you are welcomesteelersfan said:thanks tonic thats just what i needed
i believe that reads 1,000 ohms per inch...& 10,000 ohms. it even says in the instructions to set the meter to the 40 kohm range meaning you're reading kilo (or 1000) ohms.toxicmx6 said:Typical measurements are approximately 1.000 ohms per inch of wire
example ...10 inch wire 10.000 ohms
