Boostaholic
Well I think I need to get my fuel injectors cleaned and balanced. So, I need to get them out. Anyone has idea if there is anything special on how to do it, so I won't break anything. I haven't touched much on engines before so I'm really a bit nervous on doing this by myself but I guess I need to do it anyway. Anyone have ideas about taking them off?
Thanx
Mici
If the European is the same as the Aussie setup{KLO3}...You Just un hook the fuel line undo the Allen kea bolts {hexagonal internal socket bolts}that hold the fuel rail on to the inlet manifold an slide it out to the right {you probobly will have to remove the air filter assembly}and then you can do what you like with them, fuel rails and all.
