Instructions
OK, since I recieved so many responses on how to make the clear side markers I'll post them here instead of responding to each e-mail.
Materials:
1/8" plexiglass
chrome spray paint
3/4-1" chrome screws
tools to cut the plexiglass with
Remove the stock marker light assembly, either prying with a screwdriver or by releasing the clip from inside the fender.
Trace the outline of the marker on to the plexi and cut out the shape. Test fit it to the opening in the bumber and trim as neccesary. Once you have the right shape break the original colored section off the marker. Remove the crews that hold the clips ont he back and drill the holes all the way through the remained. Set the cut plexi in front of the assembly and tap screw holes half way into it. replace the stock screws with the chrome ones so that they go through the marker and tp into the holes you have made in the plexi. Once it all fits take the plexi off and spray teh inside of the marker with the chrome spray paint. You can either you clear bulbs or colored ones depending on your local lighting laws and how daring you are. Reassemble the marker and snap it back in to the bumper. This will work for the front and rear markers ad they are the same.
