The popping when turning could be the strut mounts. They should not be cracked. Also check your wheel bearing. You can have someone put their hand on the hub of the wheel while you move the car or turn the car slowly. If you/they feel popping and stuff, the wheel bearing is probably bad. The clicking may or may not be the same problem i had but it seems similar, and my problem was that the VRIS was not connected properly. For that you will have to refer to the diagram of your motor's VRIS system, which can be found by searching.
