My clutch started acting strange tonight. Everything was fine, except the brake warning light on the dash occationally lit up whenever I hit the brakes slightly hard, so I figured the brake fluid just needed toping up. This happened a couple months ago, so I topped up the fluid and it's been fine ever since.
Suddenly, I noticed the clutch was engageing very close to the floor as I started in 1st. Then the clutch pedal began losing pressure and I couldn't get out of 1st gear, so I stalled the car to a stop. I topped up the reservoir and started up again in neutral. I found that when I shift and brake often, the clutch will stick to the floor again not allow me to shift, but if I wait between shifts and don't hold the clutch in until I need to shift, the pressure in the pedal seems to build back up a little allowing me to use the clutch just long enough to change gears. Also, the brake light came on almost each time I used the brakes. I managed to drive my car about 20 miles home through city traffic trying not to leave 2nd gear.
Now that my car is home, what should I do to look for the problem? Does this sound like the master cylinder or the slave, or something else? Is it normal for this kind of problem to happen suddenly without much warning? My car was shifting normally this morning.
