My clutch pedal is wierd. Sometimes when I release the clutch slowly, it like clicks, like it stuck and then lets go. I've tried oiling, but it seems to be a mecanical thing with the spring holder or something.
Anyone else have this problem?
I had a toyota tacoma that did the same thing. It would click everytime I released the clutch, I tried wd40, etc.....
About a month of that and I had to replace the master cylinder. You should follow Imports advice and check for leaks.......
Check the ignition inhibitor switch... It's the little plunger switch up under the black facia that hides all the ugliness above the clutch and brake pedals. It's activated and deavtivated by the clutch pedal. Sometimes the plunger will stick and click when it pops out.
