1 - 17 of 17 Posts
What will cause the clutch pedal to stay on floor? I went to start my car this morning and pushed the clutch in and well it stayed in? Will not let me put it in gear or anything. Like the clutch pedal is still up but it's not? Any ideas what it could be? Just wondering if it could be in the pedal or if i'm going to have to pull the transmission?
Clutch master cylinder is bad...happened to me last month. Can you pull it back up and use it to shift or is it just flat? If its just flat it could be a broken fork on the throwout bearing.....i just changed the clutch ms and bled the lines and it fixed the problem.....
Good luck!
'nix
It stays on the floor with no pressure what so ever on the pedal. If I pull it up it will not go into gear. Unfortunately I think it's something broke in transmission. I will be pulling it apart in the next few days. It was doing good up until it got real cold one night and the clutch was a little stiff the next morning when I when to start it. I think I will start it in gear and drive it to a friends shop that has a a lift and a HEATER!
try bleeding it?
Was looking on the transmission where the fork is... Pushed it and came back when I let it go, still had plenty of pressure... I wondering it the throw out bearing could have slipped... Anyone here of that?
the slave most likey went. it is good practice to replace master and slave cause just one new one places a lot of strain on one old one and will wear it out quick. if it went a little stiff then went it could be master. I say replace both cause it eliminates confusion and it'll only have to be done once. if you only buy one I'd buy the slave.
good way to check is to grab the slave rod and try to push. if its tough and moves the fork than ur slave is fine. if its easy and the fork doesn't move than slave first.
hope this helped.
x2 on double checking the slave/clutch master cylinder. They are always the culprits in clutch pedals stuck to the floor.
Damn been to busy with the holidays I haven't had a change to tear into it... I will check the slave rod and see if it is the culprit. I hope it is because that will save a lot of hassle... Now how easy should it move if it is bad.. Or could I move it at all (by hand) if it is still good? I will check it today when I get off work..
Well i got around to replacing the slave cylinder and unfortunately for me that was not the problem. Let me get a little more into detail about what it is doing.... Clutch pedal is on the floor, you can pull it up with your hand it will stay up only because the spring is holding it up. You can literally thump the pedal and it will go to the floor there is no pressure up/down movement of the pedal what so ever. Yet I push the slave in and it comes back out..... What should I consider doing next....
I appreciate everyone's input so far
Thanks in Advance,
Joey
i would say do the master cylinder next.
I thought the slave cylinder was the problem on mine, but it ended up being the master
Discussion Starter · #14 ·
All I could do is gravity bleed it since the is no pressure in the pedal. It just stays on the floor. But on top of gravity bleeding it I did pump the slave cylinder to get any air out... I think I will purchase the master cylinder tomorrow and hope that is the problem? Any one have a guide on how to get the master cylinder out? Do I have to remove the steering column? I will try and figure this out tomorrow. And will if that's not it it is definately in the transmission.:(
Discussion Starter · #15 ·
Clutch Master Cylinder
Well after waiting on VatoZone to bring in the part I just went ahead and ordered the Rebuild kit for it which was 17.99 compared to the 60.99 for a new one. Great easy for a DIYer. Fairly simple comes with a new spring,seal,washer, "rod", and lock ring. Removed old one and installed new one in about 5 minutes tops. Installed everything. Filled to the top with brake fluid. Opened the bleeder valve at the slave cylinder, then I attached a hose to it and then submerged the other in of the hose in a bottle of brake fluid. Started pumping the clutch by hand since it still had no pressure. You can see all the air being let out in the bottle of brake fluid, and it just sucks nothing but brake fluid in since it's submerged. Did this until there was no air in the line closed the bleeder valve. Began pumping the clutch again to build up pressure and wala good to go....
Thanks everyone for your help. I was thinking about dropping the tranny. Thank god I didn't have to!
good to know it worked for you, thats what my problem ended up being. Thought it was the slave at first but ended up being the master
I did the same thing as you....was so worried that it was the transmission that I put it off for a week. Ended up being an hour fix.....
'nix
1 - 17 of 17 Posts
