1 - 18 of 18 Posts
looking for opinions on running a higher level (dual friction/puck style) n/a clutch on the F2T.
will it hold up to 250 ft lbs torque? 300 ft lbs torque?
thoughts, opinions etc.
1st n/a clutch will not fit on the flywheel. too small. the turbo uses 240mm vs 225mm n/a. you can buy ebay stage 3 6puck clutch, they held up great on project primer
i'm using an n/a flywheel also.
just wondering... why?
in that case, you should be fine.. I do have 2 brand new 6 puck n/a disc laying around is you interested..im running one on my n/a and it help 113hp shot nitrous without slipping. and still use the car for daily driver.they are kevlar
this is for the MX-7 project i'm working on. the factory b2200 clutch/flywheel setup is not gonna hold the F2T torque.
if it held up to ur n2o shot and u can daily drive it that's basically all i'm looking for.
what flywheel clutch setup did you use ademan? brand i mean.
yeah i've singled it down to them of buying from a semi-local place here.
from what i've gathered on mazdatruckin...
i can use any n/a FC clutch (which gives me ceramic, puck, dual friction etc to choose from) but i have to use either the b2000 or b2200 pressure plate and flywheel.
i dont forsee that being a problem.
Reactions: SixSick6
the one i bought on ebay for the n/a is called EZclutch, they have a website, and there clutch are pretty good, heavy duty pressure plate, 6 puck disk rated for 375tq.
eBay Motors: 83-92 MAZDA 626 MX-6 323 RACING STAGE 3 CLUTCH KIT B6T (item 350139950368 end time Dec-19-08 18:31:28 PST)
this is the one you want for the n/a. the n/a f2 uses the same disk and pressure plate as the 323 turbo. this is a complete kit and they have a good customer support when to talk to them on the phone. overall great experience with the clutch so far, its alreay over 6k miles on it.
thanks for that.
found out i also have the opiton to go with the n/a FC RX-7 clutch discs.
so at least i've got a few directions i could go.
Reactions: ademan
thanks for that.
yes, the n/a fc rx7 uses the same disc as the n/a probe/mx6/626/323 turbo.the pressure plate onthe fc will need one hole drill out for fit the n/a f2 flywheel. but you can alway use the 323 turbo/escort pressure plate for direct bolt up to the n/a f2 flywheel
I dont have nuttin against the ebay 6 puck clutches but i dont trust dem for some reason. they seem to0 cheap to me. i have had a act 6 puck without springs for 2 yrs n its great, no slipping but i think the pressure plate it killing my slaves, i been running through them. But if it works why stop
southbend ofe ftw. had mine for a few years, beat the crap out of it plenty of times making over 300ft lbs. never slipped once
My stocker isn't slipping on my 57 trim. If you're going to be going with any garrett turbo, I would stick with the stocker. The torque spike in the stocker and hybrid is what kills the clutch.
I am using an Exedy Sports organic MZK6806SO.....its a pretty much the same as a stock system except the cover has 1900lb clamp pressure instead of 1200lb on the stocker. I wanted to steer clear of puck clutches as this car gets driven in stop start traffic.
I was going to get a special one done up like a couple of people here in Oz have got with 2600lb clamp, which is made up out of Rx7 springs and different bits and pieces....but I needed it in a hurry, and couldnt wait for the other one to be made up.
Discussion Starter · #16 ·
u mean stock GT??
i can't use a stock GT clutch.
Discussion Starter · #18 ·
tbird to start.
i don't want to worry about tuning while i'm working out kinks in a swap
1 - 18 of 18 Posts
