I was just wondering if- When your clutch starts to wear out, will the shifts get sloppy and hang up every once in a while? It has warmed up alot around here and I have noticed recently that my shifts are getting slopier, cluncky and starting to hang up more. I was going to switch out my transaxle fluid with redline, but I was wondering if I switch out my clutch soon will I have to buy more redline. Is this common on a warn clutch or do I have something else wrong, maybe shifter bushings worn? I know these are probably common knowledge questions, so please don't think that I am too stupid.
these really arent common knowledge q's, but when the clutch starts to wear out, it will slip when starting from a stanstill, and during hi-rev shifts (i.e. when racing)
the rough shifting can be caused by many things.
if you drop the tranny in order to change the clutch, you will have to drop fluids too...
Hey thanks, that helps!
