1 - 12 of 12 Posts
I just got a cel today, pulled the codes and got EGO RICH, I guess that is 02 sensor. My car has been getting really bad mpg, I filled up and have since gotten less than 200 miles and have maybe 1/6 of the tank left.
Im going to replace the 02 sensor but am wonder about a few things. I cleared the memory after pulling the codes and have driven a few miles and have not gotten it again. I wonder if there is more to the running rich than just the 02 sensor.
The codes are different on earlier cars but on mine a rich condition on deceleration occured because of a problem with the ISC system. Next time you're driving see if you can find a long downhill slope and stay off the gas letting the car decelerate by itself to see if the code pops up again. btw an A/F gauge is extremely helpful in this kind of situation. Do you ever get a high idle @1000 rpm after the car is warmed up?
If you find these symptoms, it may not be the O2 sensor at all. Instead opening and cleaning the ISC valve and air valve on the back of the TB might be helpful.
No my idle is pretty decent.
On cold start up its at 1.5 after maybe 5 minutes at idle its down to about 775. it usually fluctuated between 750 and 775 depending on wierd stuff like if im facing uphill or downhill or flat. Maybe its just me I dont know.
I had a problem with fuel pressure regulator and replaced it. For psi reading I got about 85 psi from pump and before replacing the regulator it was 85 psi to the injectors. After replacing regulator it says 65 psi to injectors and I know that is about double what it should be But it doesnt seem that bad. Ive gotten bad mileage since Ive had the car.
not an expert with fuel system at all and am 99% sure it's something to do with the 65 psi at your injector if that is in fact double the normal pressure.
the check engine light comes on for a reason, reseting the ecu does nothing but turn off the lgiht for a while, but this still mean that at soem point in time something was wrong the triggered it so u may want to look into it especially if you know u did not trigger it by some mod u did ect....
if you have that much pressure to your injectors. check for a vaccum leak. low vaccum makes the FPR raise the pressure.
I'm having the same problem lately, at idle my car is a steady bar rich and my rpms are at 1100. This is after the car has warmed up, too. oxygen sensor was replaced last spring, I forget which brand I used. When i push the clutch in, the rpms seem to drop back to normal. No check engine lights are present...should i give the ISC and EGR a cleaning?
sweet, what is that from?
I have both probe shop manual and haynes. Dont remember seeing that.
Where do you think it's from? :D
(1991 Mazda MX6/626 Factory Workshop Manual)
Im still a grasshopper.
I wonder if i didnt look hard enough.
If it isnt in the ford shop manual, then mazda really is better.
Im going to check later
but that looks way to clean to be somthing that you just scanned, do you have it on cd or somthing?
Unless im the only messy one
Heh, Majik scanned from the MAZDA shop manual, not the Haynes pile-o-crap.
This thing is the MX-6 Bible and it makes the Haynes manuals look like someones drunken scribbles in the liner of a Gideon bible.
About $70 from a Mazda Dealer, or you can see them on e-bay occasionally for $15-20
Discussion Starter · #12 ·
I know the difference I have the ford shop manual. Comparing it to the haynes is like comparing an essay to an outline.
1 - 12 of 12 Posts
