MX6 Mods!
Intake:
Hot shot: http://rr-racing.com/intakes.htm
PRM intake: http://corksport.com
Modified Prelude intake: http://www.mx6.com/forums/showthread.php?s=&threadid=32967&highlight=prelude+intake
Home depot: 3” ABS pipes to make any style you want.
In my opinion the best intake is the home depot intake or the modified prelude intake. Both are cheap to make and yield the same results. The prelude intake will look better than the home depot intake. The part number for the K&N filter that will fit a 3 ½ inch ABS pipe is RU-3130. It will also fit a 3” pipe extra clamping is just required. The Cold Air intake will make your car sound different as well as give an approximate 3-5 hp
Exhaust:
Pacesetter catback: http://nopionline.com
Borla Catback:
http://www.spmotorsports.com/probe_exh_systems.html
Brospeed Catback: http://www.spmotorsports.com/probe_exh_systems.html
HKS Catback: http://www.spmotorsports.com/probe_exh_systems.html
Greddy Catback:
A Muffler is not a performance upgrade! You will gain if you are lucky 1-2 hp by adding just a muffler, the stock muffler is already pretty decent. The key is to get mandrel bent pipes with a slightly larger size. The size of the piping is based on your future plans for the car. If you plan on staying naturally aspirated 2 ¼ is fine. If you plan on boosting or using nitrous 2.5-3” is best.
Once again here is my personal opinion. All of them are overpriced! If you live in sever weather conditions then I might see the need for stainless steel but otherwise I think it is better to have a custom catback made. I ordered the 2.5” mandrel bent pacesetter catback and had my own resonator and a different muffler put on. The sound is basically based on personal preference. A well designed catback will net 5-10 hp once again that is being generous.
Underdrive pulley:
As far as I know there is only one company that makes one and that is http://unorthodox.com. I have heard hearsay about custom made ones but havnt heard much more that that. The pulley does just what it says it underdrives. It is lighter and frees up Hp by reducing rotational mass on the crank. It does come with drawbacks though. Because it is smaller it it doesn’t turn your accessory belts as fast. This will cause AC to not work as well and it also may effect your power steering at idle as well as your alternator output at idle. I have heard rumors that because it doesn’t have a dampener to reduce crank vibration it can kill a motor. I have had mine for almost 3 years now with no ill effects. The pulley will let your car rev slightly quicker and gain around 5hp
Thermal spacers:
http://www.outlawengineering.com/index.html
These are spacers that go between the intake manifold and the head. The full kit comes with a spacer that will go between the throttle body and the Intake manifold. These are not really a power adding mod. These will help keep the power as your car heats up by reducing heat soak. The throttle body gets very hot because it has hot coolant running through it. The Heads are hot because of the coolant combined with the combustion process. The spaces isolate this heat from the intake manifold keeping incoming air cool.
More to come......
Intake:
Exhaust:
Borla Catback:
Greddy Catback:
Underdrive pulley:
Thermal spacers:
More to come......
