Hey, I've got a 1994 MX6 LS ATX, and I've recently been developing a few problems... and I've had a few others that have been with the car for quite some time! I never knew this place existed, but from what I've searched online, it seems like there are quite a few "common" problems with these cars. A few of my car's "quirks":
I'm having two other (semi-major) problems that I haven't really seen anyone mention:
I'm particularly curious to know about the things that I haven't found any information on (the last two in the list); however, do any of these sound familiar to you MX6 owners?
- Transmission jerks hard occasionally going from first to second gear; feels like you hit one huge pot hole. Doesn't do it all the time, and if you release the gas at just the right time, you can pretty much make it go away.
- Driver's side power window buttons stop working; in my case, the window would go down but it wouldn't go up. Really hard to find a replacement module... went to about seven junk yards before I found one... they said it's probably their second most popular item on an MX6 around my year.
- Oil in the spark plug wells. I had this problem and it kept getting worse and worse until I went and put some major money into it... new valve cover gaskets seem to have solved the problem. Those spark plugs are way in there! I've never seen another car with holes that deep for them, and when the oil gets in there, it's a huge pain to clean it out sometimes.
- The cup holder has a tendancy to fall out when you've got a hot drink in it. Never a cold drink, although I'm sure that's just my luck. Either way it falls out a lot.
- When it rains, it's virtually impossible to de-fog all the windows. Maybe it's because this is a really humid area or something, but if I don't crank the heat up full blast, I run the risk of mowing people down when I want to change lanes!!
- I have a bad belt "squeak". It's the one that connects my alternator and my A/C, among other things. When I start the car, the belt lets out a decently loud "squEEak" and then it stops. If I proceed to turn on the A/C, I get the most horrible noise ever created. If I accelerate really fast when it's doing that, the belt snaps and my battery light comes on. I replaced the belt and it lasted two months before the same thing happened... and now it seems like it's starting to squeak worse and worse again.
