Screws Suck
the story of my life, we get screws that are stuck or broke all the time at work. some of those are in the most frustrating places. i feel your pain, if it is in the front.
you may need a hammer to tap the ez out with while turn it, also squeeze the ez out in a pair of vise grips to turn it.
should back right out.
if you get a #3 ez out, drill with a 5/32 bit.
if you get a #2 ez out, drill with a 1/8 bit.
if you get a #1 ez out, drill with a 3/32 bit.
Info Note:
if the ez out (or extractor) have a sharp tip on the end, sand it off, then you will not have to drill as deep. but be careful and not to start sanding the flutes off. just sand the point off.
[Edited by smachan on 04-11-2001 at 08:19 AM]
