Has any anyone tried to fit cruise control to their mx . I've just found a white 93 manuel in a local srappy almost complete except both rear lights and spoiler are gone. I was wondering how difficult it would be to fit cruise control to my 96 auto.........any ideas chaps............adrian
Well
The cars is SA got the wiring installed already so it is almost like microsoft windows - plug and play except woth out all the constant reboots that's required from Microsoft.
Jokes apart your biggest prob would be to calibrate the speedocruise but other than that it should be smooth sailing al the way with the harness in place already.
William
Adrian.. if you get the chance.. go for it.
you will need:
The actuator (big diaphram jobby) and the cable going to the accelerator pedal.
The switches that are on the steering wheel (or the wheel itself)
The main cruise control switches on the dashboard.
The cruise control, control box.. under the steering column on a bracket.
brake pedal switch you shold have, and the clutch pedal switch you don't need.
All the necessary wiring should be on the car already... fitting should be straightforward.. or just ask for help.
John
