Discussion Starter · #2 ·
also i have a leak in the banjo bolt area. it looks like it leaks between the seals of the washers. could it be the washers, bolt, or both.
Probably just the washers. I'd pull the banjo bolt out and take one of the crush washers to a Ford or Mazda dealer and let them match it up for you. That's what I've done.
The washers are supposed to be a one time use only. So if they are reused they tend to leak. Just get the size and go to Pep Boys. Look at where they have the nuts, bolts and screws isle. There they should have a big black cabinet with lots of drawers. Open one of them and there should be different sizes banjo bolts and next to them different sizes copper washers. Just fit one that suits your needs.
