1 - 17 of 17 Posts
that was my idea to, but I have to find interesting gauges, tacho, etc... is there anytning more interesting than standart ones
I like this style. They match my wideband O2 gauge.
NORDSKOGINSTRUMENTS.COM They are the street digital series.
They come in a few different sizes. I like the smaller ones because they are cheaper and you would be able to fit more of them where the stock unit was.
That is the style I was going to use to replace everything. Now I plan on outputting it all to an LCD and have a computer monitor as my gauge cluster :p
ok, so here's my question - can I make a custom speedometer? For example I buy tacho, spedometer, and few other gauges and install oem speedometer place?
I searched forum but I didn't find anything or smth like my idea.
P.S.
there is smth I found - installed in probe
Probe.lv Klubs: Uzklik??ini uz att?la, lai aizv?rtu ?o logu
That gauge looks as if it is off of a Prorsche... i know because my friend has one.. i have always wanted one ;)
I was thinking about using lcd monitor as well - but how can I connect all the info I need to that interface?
you could also just do some electronics work or pay a local electronics company to make different boards for each one of your gauges, then you design the way they are layed out and put them together.
Discussion Starter · #15 ·
I was thinking about 2 or 3 displays in speedometer place, but how can I connect them, to work as I like?
1 - 17 of 17 Posts
