Has anyone ever replaced a "oxygen valve"(an extra valve in every cylinder that injects air not the intake valve another one) in their cylinder head, my car is burning oil and i need to replace the o-rings if anyone knows how to do it please post.
thanx
There is no "oxygen valve".
If you are burning oil on a cold start up it is most likely your valve stem seals.
Magik8 has an excellent tutorial on how to rebuild a head in the projects section.
Read...young grasshopper.
drdemux said:
if it's not the oxygen valves that are causing you to burn oil it MUST be the piston return springs. try repacing those.
I know I'm hypocrite, but lets not be a smartass, he might believe you.
CKYPETER, you have two intake valves and one exhaust valve on each cylinder. All of them have whats called a stem seal, it keeps the oil from valvetrain from leaking into the cylinders.
sorry man. i just had to. picture me laughing my a$$ off. i never heard the one 'oxygen valve' before.
on a serious note he could also be talking about piston compression rings or the oil control rings. CKYPETER - how about describing your smoking symptoms in more detail. ie at startup, when cold, warm, idle, constantly...etc.
