· Registered
are our windows belt driven or do they have those metal regulators? mine clicks goin down and then goes very slow on the way up. i had it apart and it looks like its driven by a belt of beads. like plastic beads! couldn't believe this but i guess thats wut it must be. anyone else had problems? just venting
· Registered
hello,
Silicone spray from mazda is really good for inside and outside of the windows. I had the same thing on my 1st generation. It helped a lot and no more times where it wouldn't go down.
I hope this helps you,
Anthony
· Registered
silicon
yeah i have some silicon spray, not from mazda but probably the same stuff. so where do u spray it, did u take the door apart to spray down there? or did u just spray it on the window? i think i'll just go off on it tomorrow with the spray. cheers
· Registered
hello again,
Don't open the whole door assembly up...just spray it around onto the weatherstrips or rubber or molding all around. Put a towel across so the silicone doesn't go onto the paint. you need to especially spray it were the bottom of the glass meets the molding. Do it from inside and outside. Have the window up all the way, roll it down, and then up and again. This really helped me, I thought it was the regulator it wasn't it just needed some silicone spray let me know how it works out.
cheers!!!
Anthony
[Edited by integrale4wd on 01-30-2001 at 11:00 PM]
· Registered
window track sucks
Man do I hate that part of my car. You should be carefull, mine started doing that, and a month later the whole dam window went straight down. I took it apart and those beads had broken off the part of the window that lowers and raises it. I went to a junkyard to get a replacement, it cost me $75 USED! I cant imagine how much it cost from Mazda. My two cents.
· Registered
oh yeah
guess that would be the time that i would say i'm goin in to take out the motor and then just take the whole assembly. the guy i go to is real lenient he lets u go look around and its pretty much an honesty system. sucker
