sometimes the red light on my dashboard comes on and stays on the one that says "rear" on it..what does it mean?
your tail light may be out or somehow not drawing enough/too much current from the system. Also, keep an eye on whether or not the "charge" light comes on, even if it's dim because that signals a dying alt
if it only when you have your lights on or when you press your brake pedal it would be a light out if its not in sync with those things i would have to say the alt too.
You say it "sometimes" comes on and stays on???
I would guess that you have a loose wire/connection on one of your rear lamps.
If it was the alt, or a dead bulb, it would be on basically all the time.
Otherwise, please elaborate on the "sometimes" thing... how often, what circumstances etc.
