1993 Ford Probe GT
Recently my 93 Ford Probe died out on me. The engine cranks but does not start. I've nailed it down to no spark from the distributor. (I tested 3 separate wires)
I've been looking around the internet for days and I cannot find any information that I need. The distributor rotor still spins but at quite a low speed, is this normal? I ask this because would such a low speed not create spark from the distributor? And is this low speed caused from a broken crankshaft, or a broken distributor? I also read online that the problem may be from the ignition coil. I just want to figure this out before I buy a whole new distributor, if the problem is much simpler like a rotor and cap, or much harder like a broken crankshaft.
I am fairly new to the whole automotive scene so bear with me haha, I have no automotive background and I'm trying to teach myself as I go.
I don't know about the low speed, the rotor does not turn fast when the engine is not running. You got voltage from the 3 wire set leading up to the distributor ? You can also check for spark at the spark plug. That should tell you if spark is getting that far or not getting there. Read up on working around a distributor before doing this. Look for any worn insulation in the small wires around the distributor.
