Guest
·Guest
I have an '89 LX and i'm swapping in an
FE3
motor. Is it true that the top engine mount won't match? How off is it? Also distributor is a problem. On my 2.2 engine, the distributor plug is a two wire, but the distributor plug is a four wire on the FE3. (or is it the other way around?) Can anybody help?
The exhaust system looks good on the FE3. The F2 headers are four-two to one. The FE3 headers are four-two-one pipes. That's nice! The only problem is the downpipe. I have a two-one downpipe. But I need a straight one pipe. I was going to chop off the end and weld on a single pipe flange. But i noticed that the stock pipe is ceramic coated. If i weld a single flange that's not ceramic coated, will the pipe get red hot? (The flange only costs $12 CAD but a new pipe will cost at least $150 CAD)
I seem to have the no cat version FE3 motor. But I don't see the eight intake ports for the VICS head. Does the VICS head look just like a normal four port intake or do I just not have VICS?
Sorry for the long post but I have just two more questions. What is the beginning and end of the redline on an FE3. And I need to know that I have the right ECU. Can anybody tell me if I have the right part number? The number under the big "F201" didn't come up on my local dealer's computer, so it's most likely for th FE. But I need to know if it's a 5-speed ECU. Can you post the phone number and e-mail of a mazda dealer in Aus or wherever else FE3 is available? Thanks.
Much gratitude to whoever can help me as my car is in the shop now getting prepped for the swap.
