I have a question on the door inserts for my 96 MX6. The inserts are starting to pull away from the door. Is there an easy way to fix this? Is this common for the car? Should I just take it into a shop that can repair this?
If I know what your refering to all you need are the little plastic clips that hold the door panel in place. My mazda dealer gave me all of them for free because my driverside door had let go. Just go to the dealer and get some and reattach the door should only cost a couple od dollars.
Thanks but I'm referring to
I'm referring to the pleather inserts. I have the leather interior and the doors have these inserts. They are starting to pull away from the center of the insert.
