EZ all, is there an easy way of removing the inside door panels on the v6.
I've got a few tiny dent's which I wanna knock back out, any idea's greatly appreciated!
I've done this so many times that it's real easy:
1) Remove the screw from the plastic around the handle and lift out the plastic
2) Remove the screw from the bottom of the hand hold in the armrest
3) Remove the screw in the door that hides behind the dash when the door is closed
4) pry out the bottom edge of the door, there are 5 or 6 snaps that you must undo
5) lift the door panel up and off the door
6) unhook any electrical connections going to the door panel
There is a keeper pin on the rear jam side too. Or at least there is supposed to be. Add that to the list and you're set.
Cheer's Xeon,
I'm gonna try it out tommorow, is it easy to knock out tiny little dent's?
Thanks
Peace Out
Be careful when doing it, because it may not pop out as excepted. It's best to do it when the dent is not embedded to deep. Many people prefer to use a little suction tool (the body shops uses it), to do the trick.
