Guest
Just curious if anyone has opened the doors on the 2nd gen MX-6? I would like to replace them myself but don't want to kill my door getting at the speakers.
Thanks!
It easy to replace door speakers
I replaced My door speakers and put a pair of 6*8 pioneers in. To take the doors off just remove the clips at the bottom and pull up very easy and it should come off.
there are 4 screws you have to remove
inside the molding of the handle you use to open the door
down inside the handle you use to close the door
on the upper right of the panel when facing it
and there is a fastner on the left side around the bend
once all of those are out, then pop her right off (should take like 5 mins at the most), all you need is a phillip screwdriver.
as for the speaker it will unplug from a harness, and positive is usually the darker color, however i would do a polarity check if you have a premium sysem (factory amp)...
-Scuba-
Hey, was just wondering if anyopne knows if it was possible to put speakers on the doors in a 91 first gen MX6 that has power windows and power locks? Thanks again for helping me, haha.
Chris
