doors and bumpers
49 Views 1 Reply 2 Participants Last post by  Stealth
does anybody know how to remove the door panels and the bumpers on a 95 mx6 ls with klze? :shrug:
There is 1 screw near the handle and lock you need to take out, pull the handle lever and pop that bezel off. There is 1 more screw in the handle you use to pull the door shut, and there is 1 screw up by the mirror, after that the door panel will just pop off with clips. Unsap all the bottom ones first and then lift it upwards to get the white clip out of the door (at the top near the window)
As for the bumpers, Just start tearing into it, the more screws you find the more you take out until it comes off :)
