Passenger window goes up/down
driver window goes down but not up
any suggestions?
I'm assuming it's a power window, yes?
If so, does the button for the driver side feel different than it used to? Could be a little plastic thing on the bottom side of the button that has broken off. It happened to me a few weeks ago.
Yes, it's power. I think they all are :shrug:
How do i check the bottom of the button?
You will need to replace the switch the has all the buttons on it for the drivers side. I replaced mine when it did that.
Don't replace it yet, it might not be the problem. Mine didnt work, i got a new switch and it still didnt work. The wiring harness may be fried, thats what went wrong with mine.Can you open the pass.window from that switch? or no?
check the motor/and the harness and check the wiring that goes through the right part of the door(where it opens).
Yes, both windows move except driver doesn't go back up.
